larged chamber volume you can hit with a 6L head?
Just curious what some of the vendors have hit trying to open up a 6L head for lower compression. What combustion chamber volume have you been able to acheive without negative effects?
Our FI 6.0L chamber displaces 77cc, we run a 5/8" reach taper seat spark plug. It flows a little less on intake and more on the exhaust. It could probably made bigger, we just haven't tried. Hope this helps.
is someone allready tired of the new motor
looking to make a blower setup?
its for a buddy of mine considering FI. He has a forged 346 with flat top pistons with valve reliefs and was wondering if it would be possible to get down to the 8.25-8.5 comp range without a piston change.
