Drag Racing Tech
6speed. 497 rwhp. 4.10s. What size tire?
Old 11-20-2002, 03:02 PM
1SlowT/A's Avatar
Default 6speed. 497 rwhp. 4.10s. What size tire?
i need to get some rims and tires and am leaning towards the 28x10.5x15 ET Drag slicks. Any ideas?
What backspacing for the 15x10" weld pro stars?
spacer? Caliper grinding? thanks
<small>[ November 20, 2002, 03:07 PM: Message edited by: 1SlowT/A ]</small>
Old 11-21-2002, 11:40 AM
Moose's Avatar
Default Re: 6speed. 497 rwhp. 4.10s. What size tire?
what gear are you running and is this a all motor set up??
Old 11-21-2002, 02:19 PM
Linear Velocity's Avatar
Moose, I'm not sure but I think he said 4.10's in the topic <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> . If you're going all motor I'd stay with 26 inch tires. I should be right around the rwhp when my 388 is done, I'm going with a 26"/4.30 gear setup in my 12 bolt. It also depends of what toruq you are making, if you're doing nitrous you'[re probably making a lot more torque than hp in which case I'd go with the 28 slick. BTW, where in OC do you live and what is your setup? Take care. ~Tony
Old 11-21-2002, 02:23 PM
Moose's Avatar
DOHHHHHH!!! LOL my fault <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Lets see,, I run a 27" tire with 4.30 and I trap about 125-126 range.. (440hp range)
So lets say you are going to run 130 +.. I'd say go with the 28" tire.. car should 60ft better with the taller tire, and really give you enough up top..
also the backspacing is 7.5 for 15 x 10 rim.. And plenty of grinding unless you get the bogarts..
Should be a fun ride..
Moose
<small>[ November 21, 2002, 02:26 PM: Message edited by: Moose ]</small>
Old 11-21-2002, 02:31 PM
1SlowT/A's Avatar
thanks for the suggestions. Would you guys use a 8inch rim or the 10inch.I like the idea of a little stability being a 6 speed.
tony-im in costa mesa. who is building your 388?
Old 11-21-2002, 02:36 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
15x10 Pro Stars, 7.5 backspacing, no spacers, 28x10.5x15 Hoosier slicks at 15 psi:
http://www.pbase.com/image/5269912
I'd go with my combo I can go 1.47-1.51 at 15psi cold and it's stable all the way down the track.
I made 471rwhp last time but have not raced since then...
Old 11-21-2002, 03:08 PM
1SlowT/A's Avatar
Pro Stock John- did you have to trim the bumper at all for the 28s? how much grinding is needed for the 7.5 backspacing with no spacer. thanks
Old 11-21-2002, 03:16 PM
LS1Tech Co-Founder
I did have to trim the rear a little bit but the rearend was farther back on the passenger side...
If you have a TA you might need to try the following... drill a small hole in the rear bumper cover where you can't see it, and run a wire thru a gromet and tie the rear bumper back a bit so you don't end up doing any cutting.
Or even try adjustable LCA's and move the rearend forward a 1/2 inch.
The grinding is significant but doable. Let me put it this way, my calipers are completely smooth now.
Old 11-21-2002, 03:31 PM
Moose, keep in mind that your car is pretty light and you race at Cecil which is one of the best tracks in the country as far as -DA and track prep. I would say if he's full weight or around there he should be trapping around 125-128 mph. Nineball trapped 128 mph with his 434 with 527rwhp, he's also a full weight M6 car <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> . The only reason I'd go with 28's is for the larger contact patch for traction, gearing wise you will be fine with 26" tires; if you shift at 6800 rpms you'll be good to about 130 mph in the 1/4. With 28" tires you'll be ending the quarter mile too low (around 6200rpms)IMO. I actually work in Costa Mesa, right across the street from South Coast Plaza. Andy's Auto Performance in Monrovia is building the big bore 388; it's an LS6 block, Stage III 6.0 heads, 236/238 .610/.610 111 lsa cam, and Grot 1 7/8" headers.
Old 11-21-2002, 03:41 PM
1SlowT/A's Avatar
my car is full weight with a 6point rollbar and heavy mufflex 4" exhaust. ive heard some good things about Andys. I hope to get the car to the track next week(clutch problems).I just ordered the tires i went with the MT ET drag 28x10.5x15 with some welds.Thanks for help
Old 11-21-2002, 03:55 PM
Cool, lord knows we need all the traction we can get with our carppy California tracks. BTW what setup are you running (all motor, nitrous, FI?) and where did you get it from, MMS?
Old 11-21-2002, 04:24 PM
Terry Burger's Avatar
I've tried them all, and for what its worth I think 26" Hoosiers are the way to go. I ran 28s for a while and they didn't hook any better for me, looked like crap, and made the car loose on the top end. The Hoosiers hook about the same as ET Drags, but feel a lot tighter @ 125+mph.
Old 11-21-2002, 04:35 PM
1SlowT/A's Avatar
hey terry. mike said i should run the 28s because i will run out of gear with the 26" slicks. i was looking at the hoosier 27" qtp. the car sounds awesome with the new setup.
Old 11-21-2002, 04:37 PM
1SlowT/A's Avatar
silver- i have the MMS 418. its an old school big bore stroker built over 2 years ago. for now all motor but once it gets dialed in ill squeeze it a bit. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ November 21, 2002, 04:46 PM: Message edited by: 1SlowT/A ]</small>
Old 11-21-2002, 05:31 PM
So the new dyno numbers are 497? I was hoping you'd wind up around 515rw or so. What is your red line and I'll check the numbers on gearing vs. tire. I know Mike likes 28's but I've just never had any luck with them. You're welcome to borrow my Hoosier 26's to give them a go before you buy. When are you racing next?
Old 11-21-2002, 05:42 PM
1SlowT/A's Avatar
yeah. the numbers seem to be lower than i expected too. redline is 6800. 6spd 4.10s
they cant figure out whats wrong with my clutch so i have to wait till monday to send them the car again to get another clutch put in. im worried about running out of gear with the 26" tires. What about a gear change?
Old 11-21-2002, 05:46 PM
1SlowT/A's Avatar
i just stopped my order on the 28" et drags from summit. i want to order tires by tomorrow so i can get them next week. if MMS can fix my clutch problems ill take the car to carlsbad saturday.
now what do you think about 8"vs10" rims
Old 11-21-2002, 05:53 PM
With 26" hoosiers @ a 6800-6900rpm rev limit you'll be able to hit 132mph. I'd go that route! 10" draglight rims for sure. Skinnies in the front will also help a bit. The 27" QTPs are OK but don't hook as well. Down the road when you upgrade rear ends switch to 3.90 gears.
Next time I see the car I'll help you get more power out of it. Was that through the exhaust or cutouts?
Old 11-21-2002, 06:07 PM
Cool, I'll be at C-Bad this Saturday with some of my buddies with Andy's cars there (MicahOWNSS and TITAN), sans my car of course <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> What color is your T/A I'll look for it. BTW I hope you still don't have stock rear, I broke mine after 14 launches on Et Drags with my 4.10's <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I concur with Terry though that 26"x10.5x16 Hoosiers would be the best route, go the extra step and get tubes and rim screws too; I have them, they seem to help with the shock of an M6 launch <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ November 21, 2002, 06:12 PM: Message edited by: Silver Surfer ]</small>
Old 11-21-2002, 06:15 PM
1SlowT/A's Avatar
ive now changed my order to 26" hoosiers. i think ill be happy. and i dont have to trim the bumper. im going to irwindale tonight with my wrx. ill take my aggression out with that car.
either way im going to carlsbad saturday so ill look for your car. thanks again
