Any free mods that can be done quickly???
Re: Any free mods that can be done quickly???
Of course if you're not doing it already, remove the jack/spare/floormats/rear cargo cover and all other loose items from the car.
Drain the windshield washer fluid.
Descreen the MAF maybe.
Pull the front sway bar.
Pump up the front tires to 45psi (track only).
Cut the bottom out of the lower airbox, aka FRA! Free Ram Air
Also, check out the EGR mod: EGR mod
And also, seeing as how you have a 98', and therefor have the bigger injectors, you can take advantage of descreening, and porting and polishing your MAF. Instrustions here: P+P MAF
Those 3 mods alone, will help quite a bit, and if you have the right tools, they're all free! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Which is an added bonus. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Going to the track tonight straight from work, and wondering if anyone knows of any free mods/tricks that can be done rather easily to better my time.
Current best of 4 total runs:
13.401 @ 107.32
current mods:
3" cut-out, K&N, 3:73's, 18psi in tires
13.401 @ 107.32
current mods:
