Got a shift light, where can I find a switched and fused +12v source?
Where can I find a switched and fused +12v source on my 99 pcm?
Like the topic says, that's what the shiftlight needs, I would normally split it up and put it in the internal fuse housing but the cable looks so good I can't do that, anywhere on the PCM have a 12v switched signal???
Thanks
-Steve
Thanks
-Steve
oh yeah, if there is a switch 12v source in my 99 pcm somewhere, could I connect there? I have this as a pin reference, dunno what to hook it to tho...
http://www.ls2.com/boggs/torques/99pinpcm.htm
I found a pink wire on my PCM, on the top terminal(blue), pin 19 is pink. 19 PNK IGNITION. POS. VOLT. I found out from some reading that GM did something cool, all orange wires are constant 12v and pink are switched 12v, very cool, made my install a lot easier. I didn't want to cut the wires up from the loom they were in and wire them in somewhere else.
Thanks for the help all.
-Steve
-Steve
