Stumped on high LT's
Old 08-20-2004, 01:24 AM
ram-it's Avatar
Default Stumped on high LT's
I have been looking at my buddies car which basically has a big cam in it and headers. His Predator showed the LT's at 25 at idle. I plugged the HPT in and sure enough they were. I tweaked the VE tables some and it helped but we are still at 14 at idle, -1.6 at cruise and 0 at WOT. Nothing I can do will get the idle down. Any suggestions would be appreciated.
Old 08-20-2004, 01:26 AM
ram-it's Avatar
To clarify I only tweaked the 400-1200 VE columns since its an idle problem. We ran the car a couple of times and it is real strong through out the RPM range to 7k.
Old 08-20-2004, 04:46 AM
Black02SS's Avatar
I had the same problem and it turned out to be a vacum leak. Fixed it and all was good. Are his IAC counts at 0 for idle by chance?
Old 08-20-2004, 11:09 AM
ram-it's Avatar
I cannot find that readout on HPT. Where is it? He has AutoTap if that has it. I can ask him to go check. For my own info what would IAC being 0 at idle tell me?
Old 08-20-2004, 11:40 AM
Black02SS's Avatar
Idle Air Control Position is what it is. If it is in fact 0 at idle, I would suspect a leak of some sort. If you check it with autotap, I "believe" there are 2 PIDs for it. One works and one doesn't (I use efilve).
Old 08-20-2004, 03:20 PM
Billiumss's Avatar
I'm going to guess it smells really rich at idle when warmed up?
The bigger the cam the more your idle Ltrims will go positive.
It has to do with the duration and lsa, your O2s are picking up some of the intake charge.
Old 08-20-2004, 04:16 PM
P Mack's Avatar
Right, oxygen sensors don't actually measure fue/air ratio, they measure the concentration of oxygen in the exhaust. If you have both unburned fuel and air, the oxygen sensor will see the air and ignore the fuel, and it will think you're running lean. Then your ltrims will go up.
Old 08-21-2004, 12:43 AM
ram-it's Avatar
Yes, there was a rich smell of fuel in the exhaust when it was warmed up or started warm. That disipated with the lowering of the VE table. So based on the size of this cam it sounds quiet possible to have positive LT's at idle which is okay so long as they go negative at cruise and 0 at WOT. Would that be a fair assessment?
Old 08-21-2004, 08:42 AM
baddogz28's Avatar
HC02SS, my car's trimming 25 at idle too- I have never had to find a vac leak, how do I go about doing that?
Old 08-21-2004, 11:03 PM
snake_charmer's Avatar
I am in the same boat with LTFT's at 25 at idle after new cam/fast intake install.
Old 08-24-2004, 12:03 PM
moehorsepower's Avatar
Default Fast Intake
We installed a fast intake on an 02 and I had tuned the car prior to the intake.after the swap the fast cause a very lean condition,hence the horsepower gain. You will have to adjust your IFR and PE for WOT..
