What weight oil do you use?
What weight gear oil do you use with your 12-bolt?? I have 80W90 right now and wondering if a heavier weight would be better with noise, etc.....
Originally Posted by Hardtop
80/90 is the right oil to use.
Bruce
Bruce
Was going to fab up a little catch can that will allow the oil to drain back in the pumpkin but would rather not go thru the hassle. The rear has done this when I first got it and is still doing it after I had a local "professional" go thru and rebuild the rear with new gears and bearings, etc... The whine is gone now because I'm using a harder gear but the pressurizing issue is still there.
Orange,
FWIW, I just changed the factory rear end fluid in my 02 Z with Coastal 85W-140. I drove it afterwards for about 10 miles and the rear seemed to be working pretty smooth. I really can't tell if there is a difference between the factory fluid and the Coastal one. No noise, rattles or otherwise abnormal sounds. So far so good!
Also, I replaced the Amsoil universal ATF in my M6 tranny with Pennzoil Synchromesh. As with the rear end fluid, everything seems to be working the same as before.
Z,
Thanks for the info. ABout a week ago I changed my rear fluid from Lucas 80/90 to Lucas 85/140 just like you. It's way quiter than it was before and has less tendency to spew out the breather. Such a easy fix for all my Moser annoyances.
I use strait 140wt in just about everything except the front end differentials of four-wheel-drives, that is the normal 90wt. I myself dont like using a multivis in a differential and for the most part, I use parafin based oils with suspended moly.
I have even been known to use a strait ISO9000 350wt in chassis' that stand on the ragged edge or driven in desert elevations.
Originally Posted by NHRATA01
Hmm, I'm wondering if maybe I should switch over to the thicker oil. Might quiet some of the whining. It should also offer a bit more "cushion" for the gears when subject to the driveline shock from clutch dumps.
