spacers for oil pump
hey well i gotta another question for all of yall.... i am putting my 99 ls1 back together and i have hit a hard spot. i put a new double roller timing chain on, and i also bought a ls6 oil pump to through on as well. well i didnt know that i was supposed to have spacers for this thing until like 5 mins ago, and now i cant get my motor back together. so i guess this is a question of where can i get the spacers for this pump to fit?!? can i use regular washers or what? please any help is wanted! thanks in advance
daniel
daniel
Try calling one of the sponsors to the right hand side of the screen, maybe they can sell you just the shims. I don't think using regular washers is a good idea, because you'd have to find some way to hold it in place to align the holes just right while tightening the oil pump to the block.
another quick question is how many shims are there supposed to be?!? 5 for all the wholes or what?
predator z-
i bought the double roller from a guy who had bought it but didnt use it, and he just sent me the double roller and the sprocket. didnt send me anything
predator z-
There are 2 spacers, one for each side. And one has a 3rd hole for the oil passage in it, so washers will NOT work! I'd call SDPC (Scoggin Dickey). They are a Chevy Dealer & sell lots of them & should be able to get you going.
ok i gotcha, i was thinking that each indivdual whole had a spacer, but i see now. thanks alot. so you think i should try sdpc then! well thanks alot guys, hopefully i should beable to get them now
daniel
daniel
well i just called sdpc, and they dont have them just by themselves for sale! so they gave me a number to someone else and they didnt have them either?!? am i just gonna have to make them or what?
I bought my rollermaster double roller timing set from someone on here and it was NIB, opened but never used. They sent me the spacers too and I installed them with my ported LS6 oil pump.... no problems. I'd just print out those pics someone posted up above and make some of have a shop make them... shouldn't be hard at all... you just need the thickness and general shape. Take them that along with your oil pump and I'm sure you can get some... that or else keep begging some of the sponsors on here for a pair of them
Just in case you couldn't read the dial indicator, my Rollmaster double chain instructions states the 2 shims are 3 mm thick. Good luck.
Edit: Maybe shoot Rollmaster an email and see if they can send you some good will spacers. Their address is romac@eis.net.au
thanks so much, i will write them right now. and thanks for the measurements and the pics. and i wish i could just call the guy, but the thing is that i bought this thing like 3 months ago and it has just been sittin around in my room
well i just emailed that address you gave me and it came back saying unknown mailer address! so i guess when i get home from work this afternoon i can try and look online for it. thanks anyway though
after thinkin about it, it is gonna be a pain to get someone to make those spacers, so i was wondering if i could just get some of that gasket maker material and double or triple that up?!? do you think that that would work?!? thanks
daniel
daniel
dan, where you at? my rollermaster set is sitting here on my floor. i'm in dfw, if you're local we could meet up and take it down to a machining shop and they could cnc you some parts i'm sure.
