Motor Setup Help
Old 08-27-2004, 08:43 PM
SSPerformance's Avatar
Default Motor Setup Help
Looking for a Setup that will be able to run 11.5 or give or take 3 tenths on motor. then maybee sometime down the road spray my way into the 10s
Old 08-27-2004, 08:53 PM
2000 Tran Zam's Avatar
Are you looking for the stock motor with just different heads/cam or replacing the motor and stroking or boring it?
you can run mid 11's with cam only if you have the right setup.
by the right setup, you need all bolt ons, including tb, pulley, headers exhuast/ypipe or true duals, and a solid suspension with traction. traction will be your biggest foe.
Old 08-28-2004, 08:01 PM
lsx24's Avatar
Good question. Also what car are you using this for? That may or may not make a difference tech wise...
Old 08-28-2004, 08:15 PM
my 98 z28. Im not shure if i wana use stock short block or stroker. how hard whould it be to get 11.5s outa a stock short block. ... also whould it handle enought spray to get me in the 10s
Old 08-28-2004, 08:24 PM
Demon SS's Avatar
auto or manual trans.? with a good set of our 5.3L Stage 2 heads and a FFHP Annihilator cam we went consistent 11.4's at 120mph.
Old 08-28-2004, 08:51 PM
AUTO what rear gears where u runing
Old 08-30-2004, 10:53 PM
you will be fine, specially with an auto. just get good tires, do a good heads/cam/nitrous setup and you will be high 10's if you spray 100-150 shot.
