Drill the throttle body or Adjust the Screw??
Old 08-28-2004, 01:38 PM
2000Z28M6's Avatar
Default Drill the throttle body or Adjust the Screw??
Seems I have not yet found which one is better. I read there are some problems with the car surging after you adjust the screw on the TPIS and I've heard people saying not to drill your throttle body cuz it will cause problems when you tune. So is there no fix besides just getting it properly tuned. Since my cam swap A/C wont let the car idle, it wants to idel but then it dies. No A/C, idles ok never dies unless its cold. All I want is to raise the idle for now. I need A/C !! A tune will come when the headers go in this fall. Also my car smells a lil rich or is it just the effects of running a 112LSA? Any temporary fix on the idle guys?
Old 08-28-2004, 02:13 PM
Another_User's Avatar
Use the set screw. You only get surging if you go to far. If you get surging, back it off a little. I posted the procedure on here, including how to do the TPS reset so the car doesn't think your throttle is always partially open.
Old 08-28-2004, 05:33 PM
2000Z28M6's Avatar
Ok I tried the screw method and the car idles ok with A/C now, but now when I got on it it felt like it never reached WOT. I dunno exactly what I felt but the car just didnt have power like it did before I messed with the screw. Maybe the car was just hot. Cuz it took me like 30-45 min till i finally got the screw where it idled rite with the A/C on.
Old 08-28-2004, 05:50 PM
2000Z28M6's Avatar
Ok heres what I'm thinkin with the throttle body slightly open now it never reaches WOT, could I have gone to far? If i did i guess i can live with it till get the tune. Cuz now I have A/C..
Old 08-28-2004, 05:53 PM
Did you reset the TPS?
Old 08-28-2004, 06:02 PM
2000Z28M6's Avatar
Yea I shut her down unplugged it turned the key for a min. turn the key off replugged back in started her back up. Has anyone had any problems with WOT ?
Old 08-28-2004, 06:35 PM
Reset your PCM and try it again. You are probably going to have problems until you get it tuned. I am surprised your check engine light is not on yet because of detected misfires from the camshaft. I have never seen any problems at WOT, nor have I heard of any.
Old 08-28-2004, 09:14 PM
2000Z28M6's Avatar
Thats true on the check engine light. I have deleted AIR and EGR and never got a single light. The cam also never gave me any misfires, or SES lights. Its weird. Car seems ok now. I think it was just heat soaked when I finally got the idle rite. Shes been running ok with the A/C on, cant start her up with it have to let it run a min before i kick it on.
Old 08-28-2004, 09:15 PM
2000Z28M6's Avatar
Thanx by the way on the help and the temp idle fix.
Quick Reply: Drill the throttle body or Adjust the Screw??
