Cam Suggestions Please
It is time to pick a cam I would like some opinions on what I should use
rcsb
3.43 rear gear
3200 stall
6.0
5.3 heads 2.02 1.57 valves, milled .30
plus all bolt ons
Plans are for nitrous aroudn 150 - 175 shot
TIA
Marc
rcsb
3.43 rear gear
3200 stall
6.0
plus all bolt ons
TIA
Marc
I am happy with my tr224 112 lsa on my basically stock motor and drivetrain. It works good as a daily driver, not to radical. I'm not sure though if it is the best cam to use for nitrous. Keep asking around for that one.
Is this for the truck?I f it is I would be a little conservative,if its for a car then the TSP 231\237 would work good with the n.o.,its got more exhaust duration and a nice lobe separation, both good for n.o.!!
LS1Tech Premium Sponsor
Marc,
I dont know how p/v will be with a 6.0l setup. That will definately be the key to picking a camshaft. Do you have the 6.0l pistons with the big dish?
Jason
Texas Speed
Jason
Texas Speed
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
i have practically the same setup as this guy, except my 5.3 heads are milled .015 and my exhaust valves are only 1.55's.
I as well want the biggest cam i can fit and still be able to use the juice (150shot). I have a TR224 but i want more lift!
So best bet is basically call around for a custom dealy? Any other suggestions?
thanks.
thanks.
