Cam Suggestions Please
Old Aug 31, 2004 | 12:39 PM
redaddiction's Avatar
Default Cam Suggestions Please
It is time to pick a cam I would like some opinions on what I should use
rcsb
3.43 rear gear
3200 stall
6.0
5.3 heads 2.02 1.57 valves, milled .30
plus all bolt ons
Plans are for nitrous aroudn 150 - 175 shot
TIA
Marc
Old Aug 31, 2004 | 01:39 PM
blu98ta's Avatar
I am happy with my tr224 112 lsa on my basically stock motor and drivetrain. It works good as a daily driver, not to radical. I'm not sure though if it is the best cam to use for nitrous. Keep asking around for that one.
Old Aug 31, 2004 | 01:56 PM
DD966's Avatar
Since your heads are done I'd go big - perhaps TSP 231/237. That cam loves nitrous too. I'd check the clearance first since your heads are milled. It shouldn't be a problem though. Go with MLS gaskets though.
Old Aug 31, 2004 | 04:18 PM
PREDATOR-Z's Avatar
Make a custom one, that fits your heads, stall, motor size etc... all in one, and only yours.
Old Aug 31, 2004 | 06:57 PM
FASTONE's Avatar
Is this for the truck?I f it is I would be a little conservative,if its for a car then the TSP 231\237 would work good with the n.o.,its got more exhaust duration and a nice lobe separation, both good for n.o.!!
Old Sep 1, 2004 | 07:24 AM
LS1SS4ever's Avatar
Tsp 231\237
Old Sep 1, 2004 | 09:07 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Marc,
I dont know how p/v will be with a 6.0l setup. That will definately be the key to picking a camshaft. Do you have the 6.0l pistons with the big dish?
Jason
Texas Speed
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Sep 1, 2004 | 09:13 AM
RutanZ28's Avatar
G5X3
Old Sep 1, 2004 | 01:46 PM
v8-7's Avatar
i have practically the same setup as this guy, except my 5.3 heads are milled .015 and my exhaust valves are only 1.55's.
I as well want the biggest cam i can fit and still be able to use the juice (150shot). I have a TR224 but i want more lift!
So best bet is basically call around for a custom dealy? Any other suggestions?
thanks.
