Fast lsx 90mm intake and tb results
Old 09-01-2004, 11:29 AM
CWK
CWK's Avatar
Default Fast lsx 90mm intake and tb results
I added a 90mm fast intake and throttle body to my a4 h/c 347.Before with the ls6 intake the car made 444rwhp 387rwtq. After the intake and throttle body the car made 436rwhp and 379rwtq. Very dissapointed in the results.
Old 09-01-2004, 12:06 PM
Gloveperson's Avatar
Was the curve any different? Did it really change your A/F ratio that much? Do you have an aftermarket MAF?
Those numbers are very dissapointing
-Todd
Old 09-01-2004, 12:20 PM
CWK
CWK's Avatar
LS6 MADE MORE POWER UNDER THE CURVE, 85MM GM MAF MADE 432RWHP AND THE STOCK 75MM MADE 436? THE AIR FUEL STARTED AT 14.0 AND FROM 14.0 TO 12.8 THERE WAS NO HP CHANGE.
Old 09-01-2004, 12:39 PM
That is so weird
Maybe your fuel system is a little overworked? What injectors/rails are you running, although the stock ones should be fine at this point.
-Todd
Old 09-01-2004, 01:13 PM
Mike K.'s Avatar
damn that sucks man, put this in the dyno section as well and you will get more feedback.
Old 09-01-2004, 02:23 PM
CWK
CWK's Avatar
30lb Injectors With A Stock Pump.
Old 09-01-2004, 05:43 PM
smokin' joe 00 ss's Avatar
Yea somthing isn't right I made 27 rwhp more than my LS6 intake and ported T/B when I dynoed mine with the FAST 90mm intake and TPIS 90mm T/B and that was on a Mustang dyno.
Old 09-01-2004, 06:11 PM
P Mack's Avatar
I think there have been a few people whos throttle bodys weren't opening all the way with the fast intake so you might wanna check that.
