Do i have a 3500 or not?
I just got my SSF 3500 installed and i was wandering if it is a 3500 or not. I was playing around with it last night, and it would stall like 2400 on the street with street tires. That sounded fine, but when i stomped it from a stop, it would flash to like 2800 and then start spinning. What do you think.
The factory tack is not to accurate, I dont believe you could not brake stall a 2800tci to 2400rpm, I dont beleive you will get a 3500 to stall to 3500 witha relatively stock motor..
Put the shift lever in manual 2nd,while holding the brakes,mash the gas to the floor.Only do this for a few seconds to check your rpm's.Converter should flash to 3500.Let me know how it works.
Tony
Tony
Tony
Tony
