What is my compression ratio with Patroit stage 2 heads
If my stock compression is 10:1, will that change at all with the Stage 2 heads or stay the same. What would it be with the 5.3L heads...
Thanks,
Thanks,
Thanks,
Thanks,
Originally Posted by GUNNAR@PATRIOT
Depending on whether you get the LS6 64cc or 59cc, the ratio will be about 10.5-1 (64cc), 11.4-1 (59cc). Our 5.3 heads heads will give approximately 11-1.
The Patriot heads will give you 11.2 compression(59cc) LS6 style.The 5.3L heads will give you 10.7 compression ratio.This is using stock gaskets.This can change depending on the head gasket being used.
