On the Strange 12 bolts, do the axles have to be pulled to change the studs?
I know on the factory 10 bolts that its a must, just curious as to whether it has to be done on the Strange 12 bolts. Also, on the 10 bolts, all that needed to be done was take a small long bolt out, slide out this plate, push the axles in a little and pull out the c-clips and the axles would come out. Since the Strange 12 bolts dont use c-clips, how are the held in?
Ok, so the axles must be pulled on the Strange 12 bolts to replace the studs and the backing plate is attached to the axles and they must be taken off as well? I thought the backing plates were pressed on to the axles vs bolted on as on the 10 bolt? How do the axles come out if they dont use c-clips as the factory rears do?
By the way, on the Strange 12 bolts, the studs are threaded in vs. pressed in.
I am doing this as wee speek it is easy just unbolt the 4 screws that hold the backing plate on and remove the axle. The is a round depresion in the backing plate drill a pilot hole from front to bace to find center then use a 1" hole saw and drill from the bact to front and there you go you can change stude from metric to standerd withe out removing ever again .
