Will I have to grind my calipers???
Considering a set of warriors or pro stars for my 2002 Trans Am. Will these wheels require grinding on my calipers? Also what backspacing should I go with? Any related info or suggestions would be appreciated. Thanks!!
Re: Will I have to grind my calipers???
go to www.slowls1.com and the pic section for a before and after. Its a royal PITA... grinding them takes about a hour each, but then you have to test fit and end up taking the rim off and on about 20times to get them ground perfect <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I have mine painted again now so its not noticebale
but you have to grind the hell outta the front
