Drag Racing Tech - Do I have a blown head hasket?
BoneStock
03-09-2003, 07:35 PM
I wasn't sure where to post this. But anyway for about the past month, when I turn off my car you here coolant surging into the overflow reservoir. Every so often it will actually over-flow from the reservoir. The car isn't running any hotter than it ever does, according to the factory gauge. I've tried everything. I just don't understand why it does it just when I turn the car off? Please help me out here.
Texas Terminator
03-09-2003, 08:09 PM
probably should be in the internal engine section. anyway, is your oil milky? coolant discolored? smoke from the exhaust? any work done to the engine lately? air in the system? sounds like an air pocket. if that isn't it, do a cooling system pressure test and/or pull your plugs. wort case senario, head or head gasket. try the cheap easy stuff first.
Pro Stock John
03-09-2003, 08:16 PM
We need to move this to internal engine, but try topping up the radiator in the morning while the car runs until the t-stat opens and check the level for a few days in a row. If it's low every day you might have a leaky hose, bad radiator, or bad head gasket.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
