Will this cam fit with my heads?
I am running some 5.3 heads. I was wondering if I could use this cam, and not have to worrie about valve releifing the pistons. Cam specs are as follows
Cam is a 232/234 .595/.598 114LSA
I will be using the graphite style head gaskets also. Thanks for the info.
Thats a lot of milling on 5.3 heads, Id think that would bump you to around 12.5:1 comp. I think. Is that what you are looking for?
I dont think many larger cams will work with those heads milled that much, but I
could be wrong.
could be wrong.
