Where can I get just an I-pipe?
I am pondering up a new exhaust system and need to find an i-pipe to buy so I can save some dinero on the install/fabrication end. It needs to go from the y-pipe, over the axle, and to the muffler. Anyone know where I can find such a piece? Thanks a lot!
Since you are on a posting binge right now, I'll get this in. I looked around, didnt see anything. I have the stock one, but it's bent up, cut-up, and has a cutout welded into it. I am considering asking someone like GMMG if they can just sell an I-pipe. Any thoughts on this?
SN95 Director
Originally Posted by n2oblkz
SLP sells intermediate pipes and over the axle pipes serperately. They are pretty reasonably priced also. Check out www.slponline.com.
the parts are under restoration.
Originally Posted by Ryan Karasek
Summit or Jegs
Summit Dynomax part numbers :
WLK-53061
WLK-54064
Cost you about $100 with shipping. Summit Racing usually keeps these in stock, Jegs will special order them. For Jegs replace the WLK with 500.
Ryan K.
WLK-53061
WLK-54064
Ryan K.
Thanks
[EDIT]: Nevermind, I figured it out, thanks!
Summit or Jegs
WLK-53061
WLK-54064
Ryan K.
WLK-53061
WLK-54064
Ryan K.
Originally Posted by dug
FC02
What are you planning on doing? I bought the same pipes from summit and used a 3" ultraflo muffler. Quiet at low rpms and louder as it revs up. It still has some rasp though.
Oh, and did you weld the two pipes together, or just use a clamp?
I had it welded. Im sure it could be clamped together like the other catbacks.
Yeah, I saw your other thread after I replied. I would think twice about having cutouts b4 the cats. Someone else did that and had problems with the cutouts leaking.
Are you thinkin about runnin cats for sound or emmisions? If its for sound Id run a pair of 3" bullets with a 4" cutout in the ipipe.
