I’m about to order Yella Terra’s, any reason not to?
I guess I’m going to go with the YT 1.7’s with a custom grind comp XE-R cam and Comp push rods. Are these rockers still holding up and fitting well?
Thanks!
Jeremy
Thanks!
Jeremy
Originally Posted by jermstyle
Thanks Gomer!
So is about right more or less?
I picked up a set from LS1 Power Plant on this board....they're sittin on my dresser waitin to get installed. From the looks of it, very sturdy, good quality peices. Can't wait to get them on my heads.
I broke a Yella Terra. I think I may be one of two people who have broken one. The shaft twisted in half inside the rocker. I will probably go with Harland Sharp rockers when I get new ones. Other than that, the Yella Terras are great rockers.
Originally Posted by matts22
What exactly do these do? Do they actually add power, or just reduce friction and wear?
quickWS6, wtf did you do that broke a YT?
Definately do not buy as a performance mod. The added benefits of the YT's are...added valvetrain reliability, reduced friction, peace of mind that these will not let loose their needle bearings like some stock ones have done. Sometime ago someone dynoed back to back and gained like 4rwhp with the YT's over the stockers but that could be to dyno variation also as it's not much.
