Jeep Rear axle problems
I have a 1984 Jeep CJ-7 with a just finished 350 chevy conversion. Tried to take it for a test drive, the drive shaft turns when i put it in gear but the wheels don't. By the way as if you couldn't tell i'm not a mechanic(carpenter). I did the conversion by asking lots of questions and doing alot of web surfing. It may be a stupid question but here goes anyway. Is my rearend fried?
I did this same conversion on my CJ7. Snapped the ring gear after about a month. Put another stock rearend in, and snapped an axle about another month later. I now have a Dana 60 rearend out of a dually waiting for install, along with a Dana 44 closed knuckle front end. Both axles will also be getting the spring over conversion.
Don't waste your time and money on the stock rearend! Find a
dana 44 or stronger and you will be much better off!
But, the 350 in a CJ7 is a BLAST!! Good Luck!
