If you throw a rod...
what does it sound like?
Coming home tonight, I heard a flapping type noise all off a sudden on the highway. I thought it might be something that came loose and was hitting the belt so I took the next exit.
The engine was kinda sputtering though as I got it to like 2000rpm to pull into a gas station.
This dude pumping gas who said he was a mechanic was pretty sure it sounded like I threw a rod.
My first reaction was that I broke a spring.
I will find out in the morning. I'm only 21 and I'm getting too old for this ****.
After I finally got to the resting location, the motor would barely idle at like 500rpm but it would still idle for about 10 seconds until I turned the car off.
The fact that I made it a mile and half after I heard the sputtering w/o the engine dying means it cant be a rod right?
I didnt see any liquid in the engine bay or under the car. I will find out at 8am.
what would be the symptoms of breaking a spring?
I have the ISKYs that have a lil dampener if the main spring breaks.
If you through a rod the engine WOULD NOT RUN! "Through a rod" means the rod broke loose from the crank and/or piston and will then punch into/though the block. He probably meant a rod bearing.
Listen to it at idle. If you spun one you will have a clunking/knocking sound and possibly a squeal sound.
I am thinking it might also be that I broke a spring and dropped a valve and the valve is grinding between the piston and the head???
But most likely seems like rod bearing.
Either way I find out in the morning.
BTW, this is an all Lunati motor that has not even been sprayed yet although it does have like 20k miles on it.
dropped a valve also = BOOOOOOOOOOOOOMMMMMMMMMMMM
that means the valve fell into the cylinder and that means you crash parts together in a confined space
wtf were you doin when this happened? just normal driving? you'd know if you snapped a rod.....there'd be **** everywhere and a hole in the side of your block.....and you'd prolly be able to tell if you dropped a valve, it'd make a decent bit of racket if it shattered the piston. pull the heads and find out
I was crusing home on the freeway.
Since I got the car back a couple weeks ago, I have only redlined it like 3 times and have been checking the oil level regularly.
lunati pistons and rods also
its the lunati 395 kit making a little over 500rwhp and no juice
I am just a little puzzled whats wrong with it considering I havent raced it in a while or anything. Might be time for a 408.
If I can recoup the crank and block, I might at least get 2 grand out of it.
Well I called Triple A and had it towed to the shop. I broke down about 10 miles from my house and 5 miles from the shop so had it towed there.
They open at 8AM so I will find out soon enough.
