help with trans/engine noise (video inside)
Old 09-23-2004, 03:40 PM
xttc2000's Avatar
Default help with trans/engine noise (video inside)
if i run the car with my foot off the clutch i get a rattling, i put the clutch in and it goes away. its been doing it for about a thousand miles now, and now im getting a grinding/rattling at low RPMS in gear with my foot off the clutch or on the clutch. the noise comes from the shifter area while moving, and on startup at idle you can hear it outside and under the car pretty well.
heres the video/sound clip http://www.freedominmessiah.com/steve/ss/noise.MOV
you can hear it when the cam surges and the RPMS drop, you may need to crank up your volume a bit but watch out because about halfway through the video i move the camera under the rocker panel and it gets twice as loud.
Old 09-24-2004, 11:02 AM
xttc2000's Avatar
anyone?
Old 09-25-2004, 10:01 PM
xttc2000's Avatar
bump.
