I just got the largest cam to date to pass tailpipe emissions testing (Cartek 3X)!!!
YEHAWWWWWWWWWWW!!!!
I just got back from emissions testing and dodged a silver bullet
I just passed the tailpipe emissions test with what I believe is the largest cam to ever pass emissions in an LSX motor! The Cartek 3X cam
(rumored to be mid/low 230-ish duration and ~0.600" lift per Dave Busch) still sounded a bit lumpy idling at 1050 RPM thru my temporarily installed Carsound CATs and Super Turbo Mufflers. The guys at the emissions testing place were giving me the evil eye
like "no way is this thing going to pass" but sure enough, with a little LS1_Edit tweaking, 2 gallons of De-natured Alcohol, installation of my CATs and a higher idle....
..... you can see the results below
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
![Nono](https://ls1tech.com/forums/images/smilies2/nono.gif)
![Rock](https://ls1tech.com/forums/images/smilies2/rock.gif)
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
congrats
question though...
You mentioned you have duals yet they had single exhaust on the sheet. That'll skew the results by half from the tailpipe in your test. (At least it does up here)
Great job though all the same, its amazing what reduced timing, methonal/akly and a higher idle speed can do for you![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
question though...
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
what did you do in the ls1edit?
Alcohol?
What did you have to pass for? 1988 Monte Carlo, or the year of the engine?
And by the way, if you'll also notice, since their tach pick-up plugs in the ash tray lighter and we all know that the LS1/6 tach signal reads only half on a typical V-8 tach, notice what their machine thought my idle RPM was!!!!
