oil pressure sensor pin outs for 98 LS1?
Originally Posted by SidewayzOZ
There is no pin out. Oil pressure sensor sends its signal straight to the guage cluster
witch pin is going to the guage cluster and witch pin is ground? there are only 2 pins. i just need to know if the far back pin is the sensor signal and if the other one is ground. the 99- up have only pin out that goes straight to the guage cluster but i have a 98
btw i do have the 99-up 1 pin oli prussure plug i dont know if it will work though, guess i will try this next
