oil pressure sensor pin outs for 98 LS1?
Originally Posted by SidewayzOZ
There is no pin out. Oil pressure sensor sends its signal straight to the guage cluster ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
witch pin is going to the guage cluster and witch pin is ground? there are only 2 pins. i just need to know if the far back pin is the sensor signal and if the other one is ground. the 99- up have only pin out that goes straight to the guage cluster but i have a 98
btw i do have the 99-up 1 pin oli prussure plug i dont know if it will work though, guess i will try this next
