3" too much??
3" too much??
i plan on getting true duals in the not too distant future and i was wondering with my setup if 3" would be too much...i plan on dumping before the axel and using dynomax mufflers...do you guys think ill have enough back pressure for the motor..i dont want to over do it, but i also plan to continue modding the car
Originally Posted by Z28Venom
Either way.. it's gonna be LOUD
my car is loud as it stands....but its raspy loud...my cousin just got his duals put on his 408ci and its sounds bad as ****...and its really not that loud until he goes into warp speed
helpppppppppppppp please?!?!?!? i9 have a 98 trans am with some bolt ons. it has slp air lip, smoothe bellow, 85mm maf, slp y-pipe and a corsa 3 inch exhaust system. it is very quick on high way but at the 1/4 mile i can't better than 13.5 at 100.40. best 60' is 2.00. i think i have 3:42 gears i am upgrading to 3:73 with a 2200 vigilanti stall kooks headers, new y-pipe, magnaflow cats. also f.a.s.t intake. where should i be in times please help any1 ty
First, capitalization and punctuation go a long way.
Second, this is in the wrong forum, and its bordering on hijacking someone else's topic.
Third, if you're only trapping 100 it isn't very quick on the highway.
Forth, stop buying SLP parts.
Fifth, you probably have 3.23 or 2.73 gears if its stock.
Sixth, get a bigger stall, a 2200 will get you laughed at.
Seventh, people have been to the 11's with just bolt ons, but don't count on it.
thanks for the feedback so far...
NOSEUPCHROMEDOWN - you think with 3" the flowmaster wont limit my flow?? i like the way my cousin's car sounds with his bullets, but i may try to do something different, still not sure
WRATH22 - what'd the five fingers say to the face.......SLAP!
how much do these flows cost and where's the best place to get them...also you have a 2.5 inch all the way through or just the mufflers??
Originally Posted by NoseUpChromeDown
It's just too much. A 346 @ even 7000rpm wouldn't use it. If I could actually use something of that size, many more manufacturers would make 4" cat-back systems. Just not needed.
3" is fine. 2.5" if you are lowered or plan to be. I have great clearance on stock height. No tip toeing over bumps, no scraps, and I pull up my inclined driveway without a problem. I know I definately gained over my ORY setup. Shaved a 10th off my time with all things being equal (my shitty lauch) and I kept trimming some off once I got better. Check my sig for numbers, pics and clips. I just think things should be consistant (same diameter as collectors) and symmetrical (thus duals). Good Luck
so 2.5 would yield me better low end...i would like to keep the low end that i have...the cam already zapped some of it so if 3" is gonna take from it compared to a 2.5 then i may end up going 2.5 instead
well i got my 3" duals yesterday.....some of the best money ive spent. my car sounds like death. the best part about it is that the car is actually a bit quieter and not so obnoxious. the drone is about the same(which isnt bad) and its quiet in the cabin, even with the windows down. I have dumps btw
True duals = wholesome goodness
