How do u removal valve seals on the car?
Old 10-08-2004, 10:25 AM
eb02z06's Avatar
Default How do u removal valve seals on the car?
I'm swapping my springs out this weekend and was wondering how one removes the valves seals without hurting them. The heads are on the car so I need to remove the seals to get to the seats. Any help is appreciated-thanks!
Old 10-08-2004, 10:33 AM
LSUxBlake's Avatar
Allan at FMS was just very careful when he took mine out, and he checked each one after removing it to make sure it wasn't messed up. If you go slow with it, you shouldn't have a problem.
Old 10-08-2004, 01:55 PM
v8maro's Avatar
They are a bitch to get off if trying not to dammage them, needle nose pliers and some lovin will work.
Old 10-08-2004, 01:58 PM
technical's Avatar
Tape up the teeth on your pliers.
