2002 PCM in 99 harness will it work?
Old 10-18-2004, 03:29 PM
GrannySShifting's Avatar
Default 2002 PCM in 99 harness will it work?
Everythign was the same harness/wirign wise between those years correct, so there should be no problem with that
Old 10-18-2004, 04:26 PM
HumpinSS's Avatar
Yup 99+
Old 10-18-2004, 04:53 PM
BADSZ28's Avatar
Sweet. So I could get a 2000 car and put a 2002 PCM in it and use HP tuners for my 02Z and 2000 F-car with a 2002PCM?
Old 10-18-2004, 05:05 PM
Camaro_Zach's Avatar
owned.
Old 10-18-2004, 07:51 PM
slow's Avatar
yes but your starting points will be wrong as far as fueling, and timing, and no egr on the 2002 computer, vs the 2K one
Ryan
Old 10-18-2004, 08:06 PM
HumpinSS's Avatar
Fueling and all that stuff will be an easy fix as he would copy and paste all the tables from the 00. I am pretty sure someone will post spread sheets of the tables from the 00
Old 10-18-2004, 08:17 PM
slow's Avatar
yeah, thats easy to get ahold of that info.
just giving a little info on the differences between the 2
Ryan
Old 10-19-2004, 12:16 PM
BADSZ28's Avatar
Thanks guys. Hope I didn't hijack.
Old 10-19-2004, 02:06 PM
no problem!
Old 10-20-2004, 09:30 AM
BAD XXX's Avatar
I'm running a '99 computer in my 2001. Just had to copy the '01 files and paste them into the '99 tables with LS1 Edit.
Old 10-20-2004, 12:03 PM
okay so functionaly all wirign outputs are the same, and I can reflash my 99 PC to a 2001. That makes things little easier
Old 10-20-2004, 12:40 PM
HumpinSS's Avatar
Yup that is what I plan on doing when i get a cable to support another year... You jsut need the appropriate vin or in your case file
