Patriot ST3 Clearance
Old 10-21-2004, 03:50 PM
TexMax's Avatar
Default Patriot ST3 Clearance
I have a G5X3 cam (with the package). Those new low prices have just about sold me on some PP stage 3 ls6 heads. Would clearance be ok without milling? I would like to have a simple install without any clearance issues.
Old 10-21-2004, 04:47 PM
WS6snake-eater's Avatar
No problem.... That's what I'm running and making good power.
Old 10-21-2004, 05:14 PM
TripleBlackRamAirT/A's Avatar
WS6snake-eater, what kind of power and what times are you putting down with that setup?
Old 10-21-2004, 10:12 PM
IntenseSS's Avatar
Is the G5X3 cam so big that you need stage 3 heads...Or are pp stage 3 the same as other peoples stage2,2.5?????
Old 10-23-2004, 04:46 PM
TexMax's Avatar
Stage 3 head from one company will flow more than stage 2 head from the same company.
Old 10-23-2004, 04:58 PM
Beast96Z's Avatar
It also depends on what size valves you got (2.05 or 2.08) and if the LSA on your cam is 112 or 114. The 2.05/114 combo will clear, but the clearences are below the suggested clearence. Anything other than that and I wouldn't try it.
