m/t drag radials after 1k and 8 passes
i took these pics today of my m/t drag radials on a 15 inch rim. they are 275/50/15 and so far they are in excellent shape. they dont peel like the bf goodrich dr do. they are still intact.
Originally Posted by chrismcdaniel
how did they hook in compairisont to the Nitto's or BFG's?
well i wasnt able to launch hard because i have a bad master cylinder so when i was going to launch hard, my master stayed on the floor. they like to be launched at about 4500rpm. i launched at 3k and they dead hooked with 20psi. i have seen a friend of mines lt1 camaro go 1.64 with 22psi.
dr
I am also planning on getting some track rims and some DR's, so any specs you have on your rims would be great. Also, do you have a stock rear, cause launching from 3500-4500 in our cars and sticking is bad thing I thought, I really don't want to launch mine any higher than 2500-3000, unless it is safe for the rear. I have goodyear eagle F1 GS-D3's now 315/35/17 and launch them from about 2000-2200 on 22psi and pull 2.0 60's but it's somtimes they hook and sometimes not, they like to jump out when I hit 3rd too sometimes.
Originally Posted by 2MuchRiceMakesMeSick
Does anyone have any personal experience with the M/Ts drag radials on the street. How do they last in comparison to a nitto?
Originally Posted by BLKTA
I have put about 700 miles on the street with mine. So far so good, but I would not expect these to last long on a daily driver on the street. The compound is much softer than Nitto's, but hook much better. Definitely more of a strip tire.
Originally Posted by ICONZ28
I have a buddy that was pulling the front tires with these on the street. Bad *** tires!
Originally Posted by sebss
thanks whitecamaross, you solidified my need for a pair of MT drags. what width are those?
i have about 1200 miles on them so far and nothing wrong with them. they are extremely good and for those of you wondering if they last or not it is hard to tell right now, but i can tell u that i do definetely see them lasting more than bf goodrich's. they are not as soft as bf drag radials and they dont "peel" the same way as bf goodrich's do under street use. i will say though that they are worse than bf drag radials under the rain. i pulled a 180 degree turn just at under 40mph under rain. not good if you ask me specially where there are poddles of water. avoid stagnant water at all costs and you should be fine. i think nittos are still the best overall tires, but they will never perform as good as these under dry conditions. my 60 ft with the bf dr was a best of 1.84 launching at 4k and spinning. with these i have only had a best of 1.98 launching at 3500rpm dead hooking but bogging. i need to have the ***** to launch at 4500 rpm and i am sure i would cut a 1.7.
i forgot to mention that they dead hooked with me without any burnout. they need little to no burnout which is a plus because that should make them last a little longer.
Originally Posted by dug
I like the fact they hook while cold. Too bad theyre dangerous in the rain. Sounds like a great weekend street racing tire.
Im going to drive them in the rain. As long as im carefull in the rain I think ill be alright.
