Open Loop Question
Old 10-24-2004, 06:00 PM
yeary03SS's Avatar
Default Open Loop Question
Hey everyone. I posted this in the truck section with no luck. Hope you all can help.
Ever since I put on the supercharger i've had trouble with open loop. Sometimes it hesitates and stumbles when moving from a stop when the engine is cold and hasn't reached operating temps yet. It does not do this in closed loop (which is why I don't think it's a fuel pump or fuel pressure problem) and never did this before the supercharger. Anyone have any ideas? Should the egr be open or closed during open loop? I'm asking this because I once got an insufficient egr flow code thrown, so maybe the valve gets stuck closed sometimes. This problem occurred with the original superchips programmer that came with the kit and is still there with Allen Nelson's tune. I'm totally stumped since I don't have any scanning stuff and it only does this some days. The last thing I can think of is maybe it's trying to go into closed loop too soon (I have a 160° thermostat)???
Old 10-24-2004, 08:38 PM
LS1Tech Sponsor
Slowhawk's Avatar
Are you sure the fuel pressure is constant?Also make sure the bypass valve on the driver side of the blower moves freely.
Old 10-25-2004, 04:42 PM
yeary03SS's Avatar
The fuel pressure regulator is new, but that doesn't mean it's not defective. Can the bypass valve be screwing with the open loop?
Old 10-25-2004, 05:13 PM
Moderator
jimmyblue's Avatar
Thermostat action happens well after closed loop
threshold (94F, stock). The open loop vs ECT tables
do command some piggy richness when cold and at
high MAP. Which you would expect a supercharger
to produce. No telling what your various tunes have
done there.
Old 10-27-2004, 04:34 PM
yeary03SS's Avatar
done there.
Hmmmmmm, would the tune make it do this just sometimes? I was thinking it was something mechanical since it doesn't occur on a regular basis, but that is just a guess. The bypass valve works fine. I don't know what else mechanical should be working during open loop that would cause this. So is there an air/fuel vs. ect temp table for open loop that needs to be leaned out?
Old 10-27-2004, 05:32 PM
Moderator
jimmyblue's Avatar
Open Loop Fuel/Air vs ECT vs MAP is the table. There is
a pretty abrupt swing from small enrichment to 1.3
fuel/air multipliers, at the higher MAP levels, across a
pretty small (few columns) temperature span. If you
have just picked up this problem as the weather turns
colder, this could be where it's at.
It's worth a try, anyway. If you can see your Fuel Air
Multiplier PID (don't know what-all you can scan with
your SuperChips unit) that would tell you whether it's
rich on account of being told (see FAM of 1.3 or whatever)
or rich on account of being wrong (fat O2s but a 1.00
commanded multiplier). Even if you can't scan that, try
looking at your ECT at the point where it "gets better".
94F is the closed loop enable temp (stock). If it gets
right, right there, abruptly then that implicates your
open loop fueling. If it gets better more gradually, and
at a higher temp, then it may be more to do with some
other player.
I have to wonder about the EGR in all of this, seems
like it ought to just go away; why keep this silly
economy / pollution kludge in place with a blower on
there?
Old 10-27-2004, 08:10 PM
yeary03SS's Avatar
other player.
there?
I appreciate all the help. I don't know how much air the egr is supposed to recirculate, but like I said I did get the insufficient egr flow code thrown once. I have no idea if it's supposed to be closed or open in open loop, but if it's supposed to be open and gets stuck sometimes, that may be causing me to run pig rich???? That superchips paper weight that came with the blower doesn't have any features, it just has the tune. Hopefully I can get some scanning/tuning software soon. Later.
Kyle
