422 results
422 results
I got my dyno numbers and car back from ARE. Results are as follows..
Stage III 6L heads w 2.08 1.60 valves (11.5 cr)
254/254 .648/.648 @ 110 (+2)
ported ls6 intake/tb
TPIS 1 3/4 headers
Stock pulley/stock airbridge/bellows
Car made 475 rwhp and 467 rwtq. Unfortunately, they did not include the a/f ratio, although they said it was 12.9/13.0
How much more power can I expect once the motor is broke in, and with 90 mm LSX & 1 7/8 headers?
These dyno numbers are lower than a lot of other big bore/stroke motors. I dont see how a fresh motor can be 70 rwhp off a similar setup, unless a pulley/intake/headers/airbridge/bellows makes that big of difference.
I am looking at the LS1 Edit file, and the VE and Cylinder Displacement tabs are the same as my 346. It seems to run pretty well, albeit a slight surge at lower rpm.
Does anyone know what effect the Cylinder Displacement parameter has on things?
TPIS 1 3/4 headers
Thx John, what effect would this have on power, and also the driveability?
FYI the tuning was done by ARE, who was once held in high esteem, so I assume they know how to tune? Would VE and Cylinder Displacement have an effect on power?
Intake, pulley and bigger headers should be an easy 35-40RWHP I would think.
Dont forget this is on ARE's dyno, I have seen 440RWHP cars from other shops dyno 390 on their dyno.
Take it to the track, I think you'll hit 127-130mph easily depending on gearing/tire/traction.
The LSX may or may not help you out, With lsx and stepped headers I only gained 10 hp on a mustang dyno.
fwiw I have dyno'd as high as 537 hp and 480 tq and as low as 494 hp and 450 tq on different dyno's and have gone from 12.8 a/f to 14.1 a/f respectively. If the car is running good just be happy with it the way that it is.
