finding LS6 PCV line?? P/N
well i have the part number 12568010 of the ls1howto site and i cant get that to pull up at gmpartsdirect or sdpc. how can i go about getting this or finding if thats the real part number. i also need 2 other things if you guys can help. i need the P/n for the power steering cooler clip and also the p/n for the pulley that is on the tensioner, just the pulley not the whole tensioner.
Here you go man:
-LS6 PCV tube #12573109.
-Power steering cooler clip #10414272.
-Tensioner & pulley #12560344.
GM doesn't sell the tensioner pulley seperatley, only as one assembly... The part# that you have listed for the pcv tube changed to the # I provided, they should all be current when you go to look them up... Hope that helps.
Mike.
Mike.
