Slipping transmission?
When I first got my PCM it was shiftin around 5800 which I felt was definatly too early, then it adjusted itself or something then shifted at 6000-6200 RPM's. Then tonight every time in 1st gear bounces off the limiter once and shifts into 2nd gear at ~6500 RPM's. I haven't tried out 2nd or 3rd gear yet to see what they shift at. Does the PCM adjust the shift points itself? My transmission doesnt feel like its slipping... The only difference with tonight is its a littler cooler out and I have drag radials on.
I just remembered that the 3-4 shift is soft as hell too. Here's a vid of the 3-4 shift. This is before it started shifting at 6400-6500 though....
http://www.p-r-o-s.net/movies/ROBFLY.mpg
Just ignore my friend at the end though
