Does anybody know flow rate on cooling system??
Old 11-12-2004, 10:16 AM
TApimp's Avatar
Default Does anybody know flow rate on cooling system??
As title says, on an ls1 motor? looking at doing a remote water pump and need to know if i can use a 20 gpm pump
Old 11-12-2004, 10:35 AM
2000Firehawk's Avatar
Try using 'search'.
One I posted = search title OEM GEN under 'external'
Old 11-12-2004, 11:53 AM
Nasty N8's Avatar
Stock LS1 w/160 T-stat flows 55 at 5000RPM
flows 45 at 3000RPM
flows 30 at 1500RPM
Electic water pump wo/T-stat flows 23 across
Would not rec anything less than stock for a street car. Also the more power you make the more cooling you need.
Nate
