Can you determine through ATAP is an O2 sensor is bad?
Old 11-15-2004, 06:28 PM
General Jack's Avatar
Default Can you determine through ATAP is an O2 sensor is bad?
My car has lost 0.5 and 5 mph in the quarter. Plugs are clean but gas mileage is down, I suspect a bad o2 sensor.
Is there anyway to check this with autotap? I have cleaned my o2 sensors with a propane torch, but I don't think that helped. Couldn't quite get the voltage test to work either. Just hoping I can verfiy bad o2s before shelling out the $$ for new ones.
Mods include LT headers with ORY & 230/227/112 cam. Its been in for 12,000 miles and over a year.
Thanks in advance.
Old 11-15-2004, 06:41 PM
RUDY@AP-ENGINEERING's Avatar
Not shure about auto tap. If you have access to ls1 edit it will show how fast or slow your 02 sensors are responding on a graph.
Old 11-15-2004, 06:46 PM
ATAP will show how fast/slow they are switching between rich and lean, I believe. Is there a benchmark for how fast healthy o2 sensors should switch?
Old 11-15-2004, 06:52 PM
Moderator
jimmyblue's Avatar
At idle it's very variable and I expect the headers may
be putting them right to sleep. You'd like them to be
switching at least once a second, more is better. The
older & grimier they get, the more they like the heat.
If you're going to buy new ones, buy the 'vette rears.
