Tuning costs
Old 11-21-2004, 11:00 PM
Lostpatrolman's Avatar
Default Tuning costs
How much does it usually cost to have your engine tuned after a cam install?
Old 11-21-2004, 11:02 PM
chpmnsws6's Avatar
Old 11-21-2004, 11:13 PM
7 Second Club
ty_ty13's Avatar
yeah...its right around there
Old 11-22-2004, 01:25 AM
jrp
SN95 Director
jrp's Avatar
Originally Posted by ramairstyle00
400-600
but dont let price be your only factor, you cant put a dollar amount on an truly experienced tuner. i know plenty of people who basically threw money down the drain on a "tune" only to have to pay again for someone who knew what they were doing tune there ****.
Old 11-22-2004, 07:50 AM
Bearcat Steve's Avatar
Having my car tuned with LS1-Edit on a dyno by someone who knew what they were doing was far and away the best "bang for the buck" mod I have ever done. I may a little on the high side compared with most, but I gained 30 rwhp and 29 rw lb. ft. If one measures mods based on $/hp, tuning is about as good as it gets.
Old 11-22-2004, 09:56 AM
LS1TECH Sponsor
foff667's Avatar
im a fan of self tuning now after my experience...overspent on a bad tune bought everything needed to tune myself then couldnt get any of the money back even though the tuner pulled the entire tune. FWIW i ended up running faster & quicker (ie mph & et) in 30 degree warmer weather(55F compared to 90F) with nothing other then idle and tranny shift point tuning. Hptuners costs ~$510 and if you have a laptop its that much easier...rent a dyno for a few hrs and read alot here on what parameters to change.
Old 11-22-2004, 09:57 AM
Silver_Whistler's Avatar
best bang for the buck is nitrous, but a close second is tuning
Old 11-22-2004, 06:01 PM
hepcatws6's Avatar
About how much did it run you to get that tune? I don't even know if I could find a good tune here in WV. Where did you get yours?
Old 11-22-2004, 07:39 PM
LS1TECH Sponsor
JeremyF's Avatar
After a cam install is one of the best times to get the car tuned. Why? cuz usually it wont run and there are alot of gains to be had in driveability as well as WOT. I usually charge $375.00 plus whatever the cost of the dyno is usually $75-$100.00 depending on time. Then we take it out on the street and test her out and MAKE SURE things are right. I feel it is the best way to make sure the car will perform @ the track without being at the track and giving the customer the best bang for the buck.
Jeremy
Old 11-23-2004, 02:26 PM
Black Z/28's Avatar
Originally Posted by JeremyF
...After a cam install is one of the best times to get the car tuned... I usually charge $375.00 plus whatever the cost of the dyno is usually $75-$100.00 depending on time...Jeremy
Mine cost $350 + $100. picked up 12hp.
Old 11-23-2004, 02:49 PM
badaSS346's Avatar
I had this happen to me with my cam only setup. Car was just crap with the old tune, funny how me and foff667 had the same problems and we both brought to the same place Anyway i had it retuned my Mikey at Rapid and not only did my car pickup 21 rwhp on "my" old dyno sheet, the drivability is increadible.
I would suggest Rapid Motorsports in PA------------------------------> Its a bit of a drive but well worth it. I drove down from northern nj and could not be happier. Mikey will get it right.
Old 11-23-2004, 03:37 PM
Cstick's Avatar
I picked up 60RWHP and 82RWTQ after my tune a week ago. My AFR was way off before the tune. I needed more than stock RPMs also. $500. Best thing I did to my car. Runs so much better.
328hp before 388 after tune
291tq before 373 after tune
