Editing transmission tables - HPTuners
I'm looking to firm up my very light/part-throttle shifts as well as my 1-2 wot shift and 4-2 downshift. I have a vig3200. Right now my shift pressure/force motor tables are stock besides tm delete and lowered shift adptation(.300). I'm not looking to blow my cooler lines off, I just want my light throttle shifts to be like my part-throttle shifts. From time to time I have a tuning related problem on my 1-2 wot shift bumping the limiter b/c the pcm is not commanding a shift(usually only at the track). I've changed my shift pts to no avail. Its almost as if the pcm relearns shortly after flashing the pcm. I'm not sure how to go about firming up shifts with out over stressing the transmission. Does anybody have a modified .bin file I could look at or could somebody look at mine to see if i'm missing anything when it comes to 1-2 shifts and increasing line/or shift pressure.
Thanks
Thanks
Moderator
Look in the HPTuners site, V-8 Transmission section,
the General section spreadsheets thread, or right here
and you'll find several of my posts with linkage to .bins
and Excel sheets (the later of these being w/ 3.42s
and a 3000 stall speed).
