Texas speed, PRC Valve springs
so how are these things. have a friend interested in getting a TSP kit deciding to go with either these or the 918 kit
i have patriot gold duals and have worked great.
Originally Posted by jrp
what are the full spec's of the PRC's: open and seat presure, o.d/i.d, and install height? and how do they differ from the PP gold?
Here are the full specs of the PRC spring kit.
seat : 140lbs
open: 390lbs
install : 1.800
coil bind: 1.07
1.290 O.D.
max lift : .660
matl : super pure chrome silicone
They differ because the PRC kit has more open/closed pressure and a different valve rate.
PRC has many new parts that will be released soon.
SN95 Director
looks close to the PP's
(jason)
Doubles Good to ATLEAST .650 lift
Coil Bind Is At .720 lift...
Springs are Super Pure Chrome Silicone Vanadium
They're Electro polished to help spring life & remove spring impurities
They're 1.29” diameter so the heads require no extra machining!
Pressures:
140#@ Seat
390# Open
(terry)
135lbs @ 1.800
385lbs open
coil bind @ 1.08
whats the valve rate on the PRC's?
(jason)
Pressures:
140#@ Seat
390# Open
(terry)
135lbs @ 1.800
385lbs open
coil bind @ 1.08
(jason)
Pressures:
140#@ Seat
390# Open
(terry)
135lbs @ 1.800
385lbs open
coil bind @ 1.08
(jason)
Pressures:
140#@ Seat
390# Open
(terry)
135lbs @ 1.800
385lbs open
coil bind @ 1.08
SN95 Director
Originally Posted by MUSTANGEATER
Aren't the springs in question made by the same company?
Not only is our Patriot Gold kit more economical, it comes with more. Our kit comes with springs, ti retainers, viton rubber seals, machined bases, and New Super 7 Locks. Some kits only come with stock locks or no locks at all....just use your old, used locks. Why pay more for less?
BTW, who is PRC? Who owns the company? Where are they located? What is their phone number? What is their web or email address? Did anyone see their booth at the PRI show?
Originally Posted by Terry@RacetechSpeed
PRC has not released the manufacturer of their spring.
Originally Posted by EDC
The AFR valve springs are coming from the same source as PP and PRC (and a lot of other places) purchase them from.
No magic here, "Associated Spring" makes them for everyone.
I've been buying the same springs in bulk for a while now.
Good pieces no matter what color!
Ed
Ed
I tried to "google" PRC (Precision Race Components) but found nothing.
I'm with Gunnar on that one. I don't think PRC are worth more than PP.
Besides, before I buy anything I tend to research the product: Who makes it, reliability, cost, etc. When RaceTech tells me that it's "secret and was never released" then usualy it means that they hide something.... Sorry, difference between .650 and .660 valve spring advertised lift is minimal. (and I'm sure that's PRC's advertising catch anyway) I'll take a proven and less expensive kit from PP.....
There is many well known companies that do not set up a booth at PRI.Setting up a booth doesn't give a company an automatic stamp that the product they sell is worthy,and better than others.PRC is handled by the proven companies that sell their products.If you need information call a retailer.
If the super 7 setup from Patriot is so good,why didn't AFR use it when they were buying the gold spring?AFR no longer uses this spring.I have friends that have broken the super 7 locks.There also have been folks on the board who have broken them.If you want something that is proven and never failed,its the GM lock.
You would think they would want the business, or is it supposed to be a secret?
