Stall and Tuning
Old 12-25-2004, 04:07 PM
BoneSS's Avatar
Default Stall and Tuning
What are the things to make sure that are touched on when the car is tuned w/ a stall?
Old 12-25-2004, 09:41 PM
Kenafin_02TA's Avatar
Torque Management: edit or delete...there's a couple of different thoughts on this depending on your point of view and your tuner's point of view. But it at least needs to be tweaked.
Shift points: Unless you're going with a real small stall...you're probably going to want to adjust these (part throttle and WOT)
I'm having to adjust my idle...but I'm running a large stall. I don't know if that's a trait of a large stall..or just a stall in general. I also had to delete an SES code. (I was throwing P0757 I think it was...from what I was reading it's only triggered in 01-02 cars).
Old 12-26-2004, 01:00 AM
BoneSS's Avatar
Thanks for the advice. It is a 2800 Vig--should have pointed that out!
Old 12-27-2004, 05:57 PM
Another thing you might want to adjust when you're adjusting the shift points is the converter (TCC) lock-up points.
Old 12-27-2004, 06:03 PM
BoneSS's Avatar
Thanks. I am deffinately going to have that worked on b/c right now it unlocks at 65+. Great for my mileage
