GP on GTO lowering springs AND.........
Old 12-28-2004, 03:25 PM
Chris @ Speed Inc.'s Avatar
Default GP on GTO lowering springs AND.........
www.ls1speed.com The group purchase is for slp lowering springs, rear sway bar and camber kit. The GP will be good through 1-15-05. All I need is five orders.
The progressive-rate spring package yields noticeably sharpened handling characteristics without an accompanying degradation in ride quality. Ride height is reduced by one inch, providing both a more aggressive stance and a lower center of gravity. Kit includes two front and two rear springs.
This package has been designed to work with STOCK-SIZE wheels and tires (245/45-17 on 17 x 8) and may cause tire-to-body contact if installed on a vehicle with a larger wheel/tire combination. Professional installation and subsequent four-wheel alignment strongly recommended. Camber kit #70027 recommended to maintain proper rear camber.
This heavy-duty rear sway bar is an easy, cost-effective way to improve the traction and handling characteristics of any 2004 GTO. Constructed from 19.05mm (stock is 16mm) cold-drawn steel, it can yield noticeable reductions in both wheel hop and rear body roll during spirited driving. Two end-link mounting points on each side make it possible to preload the rear suspension for improved launches in drag-race applications. Includes low-deflection K-prene bushings.
PART DESCRIPTION
SLP70027 Camber Kit, 2004 GTO $169.95 GP price $144.65
SLP70026 Springs, 2004 GTO Lowering (set of 4) $249.95 GP price $212.46
SLP73004 Sway Bar, 2004 GTO Rear, Heavy-Duty $159.95 GP price $135.96
PLACE ORDER ON LINE OR CALL US ON OUR TOLL FREE NUMBER
1 866-LS1-SPEED
847-897-0767
WWW.LS1SPEED.COM
If you have any questions at all please email me chris@ls1speed.com; please do not pm me.
File Type: bmp
File Type: bmp
File Type: bmp
Old 12-31-2004, 09:41 AM
bump d bump bump
Old 01-06-2005, 09:29 AM
Default "do it"
one week left any more orders
