GP on GTO lowering springs AND.........
www.ls1speed.com The group purchase is for slp lowering springs, rear sway bar and camber kit. The GP will be good through 1-15-05. All I need is five orders.
The progressive-rate spring package yields noticeably sharpened handling characteristics without an accompanying degradation in ride quality. Ride height is reduced by one inch, providing both a more aggressive stance and a lower center of gravity. Kit includes two front and two rear springs.
This package has been designed to work with STOCK-SIZE wheels and tires (245/45-17 on 17 x 8) and may cause tire-to-body contact if installed on a vehicle with a larger wheel/tire combination. Professional installation and subsequent four-wheel alignment strongly recommended. Camber kit #70027 recommended to maintain proper rear camber.
This heavy-duty rear sway bar is an easy, cost-effective way to improve the traction and handling characteristics of any 2004 GTO. Constructed from 19.05mm (stock is 16mm) cold-drawn steel, it can yield noticeable reductions in both wheel hop and rear body roll during spirited driving. Two end-link mounting points on each side make it possible to preload the rear suspension for improved launches in drag-race applications. Includes low-deflection K-prene bushings.
PART DESCRIPTION
SLP70027 Camber Kit, 2004 GTO $169.95 GP price $144.65
SLP70026 Springs, 2004 GTO Lowering (set of 4) $249.95 GP price $212.46
SLP73004 Sway Bar, 2004 GTO Rear, Heavy-Duty $159.95 GP price $135.96
PLACE ORDER ON LINE OR CALL US ON OUR TOLL FREE NUMBER
1 866-LS1-SPEED
847-897-0767
WWW.LS1SPEED.COM
If you have any questions at all please email me chris@ls1speed.com; please do not pm me.
PART DESCRIPTION
1 866-LS1-SPEED
847-897-0767
WWW.LS1SPEED.COM
