VE tuning question (HPTuners)
I have HP Tuners, was doing VE tuning yesterday.
I disconnected the MAF and started logging.
I found my car wasn't running off of the primary VE Table, but using the secondary. After a few hours I got my LTFTs pretty close using the adjustments on the secondary table, it was late, called it a day.
I transposed the secondary to the primary, evened it out (secondary has half the resolution as the primary), smoothed it, plugged MAF back in, LTFTs rose about 4, putting me around +2/+3 from -2/-1/0.
How are you guys able to tune using the primary VE table?
Thanks
Ben
Thanks
Ben
Primary is only for the 01-02 cars. Sounds like you got pretty good results...Now just Scale the MAF table by 4% and you do some more driving and logging. You might have to scale it some more once the trims settle in.
Originally Posted by HavATampa
Hey Ben,
I was getting ready to try this procedure that WS6snake-eater has outlined too and was wondering how do you determine in HP Tuners what VE table it's using at the time, primary or secondary? Where does it show that info?
If your software is showing a 2ndary table then that is the one use. If you do not have a 2ndary then you use the primary. Just remeber to copy the info from the 2ndary to the primary and fill in the blanks, before plugging the MAF back in.
I found out by realizing that changing the primary wasn't doing anything... what really sucks is that the primary VE table goes by 5's, the secondary goes by 10s.
I'm not sure, all I know is that small changes will show in your LTFTs... I changed some of mine by like 20 and nothing changed in the LTFTs, thats how I discovered that I had to use the secondary table.
Originally Posted by tomaSS
Then I guess I have been wasting the last two days of my time! Since my car is a 2000, then I use the secondary table? Then once that is done, then copy the secondary to the primary? Damn, I thought I knew what I was doing!
But yes, when you are in SD mode, the VCM reference secondary, when the MF is functioning and plugged in, it will reference the Main... tune with the secondary and copy back to the main and derive averages for the missing rows... I posted an excel calculator in another thread in here is you just want to download it!
You need to tune your MAF table. Your VE changes don't override your MAF table, and any intake changes (MAF porting, lid, etc.) will throw off your MAF table. So your trims could be dead-on in your VE table, and the MAF table will still say you are lean because of unreported air.
So once my VE table is correct then I scale the MAF Table? I am confused because some people scale the MAF Table, some scale the IFR Table and some just say to change the VE Tables. I think the more I read, the more I am confused! I guess there are many ways to tune a car. I just don't know which way to go.
Ok, thanks, that makes sense. Don't feel bad tomaSS, there's a lot of members in the Confused Club, I am one of them. But the more I read on here and the more questions I get answered, the less confused I feel.
Originally Posted by txhorns281
If you're in SD mode, it will reference the secondary VE... (SD mode = MAF fail mode) Either unplug the MAF, or set MAIL fail frequency to zero!
