starting the spring swap out wrong
Old 01-05-2005, 08:59 PM
LSONE's Avatar
Unhappy starting the spring swap out wrong
well i get the first spring off pretty easy, pull the seal and retainer then the valve slipped. it didnt fall all the way out, its still in the guide thing, but what can i do to push it back up? i had the timint dots lighned up so i dont know how it fell so far, piston 1 should be TDC anyway i'm gonna switch to the straw method.
but in the mean time, how can i get this back up short of removing the heads? this must be the cam install from hell, please give me some advice..
Old 01-05-2005, 09:06 PM
jmX
jmX's Avatar
turn the engine by hand and the piston should push the valve back up.
Old 01-05-2005, 09:17 PM
DrkPhx's Avatar
Exactly. In fact turn the engine over to bring the piston up to TDC for each intake/exhaust spring set. This will prevent the valves from slipping all the way down and is much faster than the air compressor method.
Old 01-05-2005, 09:19 PM
LSONE's Avatar
well on the ls1howto.com guide it says you can judge tdc by the dots on the timing chain. that was wrong
Old 01-05-2005, 09:41 PM
TT-TECH Veteran
Inspector12's Avatar
Well if you want to you can use a Good pen magnet if they are the stock valves and see if that will pick it up the one I have from Home Depot I know it would it is a strong SOB. But like the other two or three guys said just turn it over slowly with a 24mm socket and a ratchet and watch witch way it is going up or down and if it goes up then keep going until you get it. Or if it is going down stop and go the other direction until it gets up . Good luck.
Old 01-05-2005, 10:15 PM
LSONE's Avatar
alright i got that taken care of but...
when i spun the crank i noticed metal flakes all over the timing chain, i'm guessing that i just have to take the oil pump off, wack the bottom sprocket on more, then put the oil pump back on? i have the shims that came with the timing chain (rollmaster double)
also, what precautions should i take to make sure i dont get any metal in my engine?
Old 01-05-2005, 10:31 PM
tomaSS's Avatar
If you aligned the dots right and followed the instructions, then you will not have a problem.
Old 01-05-2005, 11:19 PM
LSONE's Avatar
i'm taking the oil pump back off this sucks
Old 01-05-2005, 11:24 PM
jmX
jmX's Avatar
Quite a few people have used that proceedure and have had no problems. I myself have used it at least 4-5 times.
Old 01-05-2005, 11:49 PM
PREDATOR-Z's Avatar
Are you sure you are on piston 1 (driver side) and not piston 2 (passenger side) ?
Old 01-06-2005, 12:01 AM
LSONE's Avatar
i've fixed my timing chain issues, thanks guys
Old 01-06-2005, 12:09 AM
PREDATOR-Z's Avatar
What issues???????
Old 01-06-2005, 12:15 AM
LSONE's Avatar
i installed it off center i dunno what i was thinking when i out it in, but i corrected that error.
Old 01-06-2005, 12:17 AM
PREDATOR-Z's Avatar
That explains why #1 was not at TDC. good luck
Old 01-06-2005, 12:20 AM
LSONE's Avatar
yeah. i just installed it stright up and 1 and 6 are tdc, so this better be right
Old 01-06-2005, 12:28 AM
PREDATOR-Z's Avatar
It will. .....Just be patient, check and double check everything before moving to next step.
Old 01-06-2005, 01:22 AM
BLASTER's Avatar
Just did this 2 days ago as well. The install document is correct and the valve movement should only be less than a 1/4" if the piston is truely at TDC. I couldn't believe how easy it was. Not knocking you just very pleased how accurate and dtailed it was about the spring part. Careful with that Oring. I guess you got the pickup tube bolt out of the pan????
Old 01-06-2005, 01:33 AM
LSONE's Avatar
well, this is my first real adventure into the internals of any car, and lets just say everything has gone wrong. but i've learned ALOT, so i guess its worth it...
Old 01-06-2005, 01:36 AM
BLASTER's Avatar
Old 01-06-2005, 01:39 AM
BLASTER's Avatar
Also, once you are done with 1 and 6, just position your ratchet with the 24mm socket at 12 oclock and rotate it to 3 oclock. You will then see the CAM gear move half that and it will be at the dot will be at the 730 position. Once done with that set. Repeat
