Speed Density?
Old 01-08-2005, 09:31 PM
BlackCamaroSS02's Avatar
Default Speed Density?
What exactly is Speed Density i hear alot of ppl talking about converting to it...what are the benefits? whats the difference from what the car runs now? Some information would be greatly appreciated
Old 01-08-2005, 09:35 PM
horist's Avatar
Speed Density is basically running w/out a MAF and relying on the IAT and MAP Sensors to tell the PCM how much air is entering the motor....
Advantages:
No MAF means less restriction of intake charge
No MAF means 1 less table to tweak to try to get inline w/existing mods
No MAF means no need to purchase an aftermarket MAF or a larger diameter MAF
Disadvantages
More time consuming to tune
IAT temperature is much more critical (being reported accurately) than w/a MAF tune
93 Camaros and Firebirds were Speed Density from the factory I believe?
Once dialed in no difference.. you're using the MAP Sensor and RPM... given that you know what cell the PCM is looking at ... then you can look at what the LTFTs are for that cell.. if + then the PCM is adding fuel which means more air is entering for that value than the PCM thinks is...
Our cars failover to Speed Density when they detect a MAF problem (or if you force an error)
Old 01-08-2005, 09:38 PM
Nickn20's Avatar
its a tune without the maf, it relys on your map sensor and a few other variables to control fueling, its a very tedious job, and is not for everyone. early mustangs pre 87, and 93 and older fbodies that were fuel injected were also considerined speed density cars.....
try searching this section you will find tons of info, how to put your car in to SD mode, how to tune it, why people do it(maf limitations/restrictions), etc.
Old 01-08-2005, 09:40 PM
Nickn20's Avatar
horist 85-93f-bods were SD, mustangs 85-86 were also and CA model 87s were SD while all the other states had mafs that year I believe.
Old 01-09-2005, 01:57 PM
I did a bit of searching and i remember someone saying you max out you MAFS at about 570hp...what happens when you max it out? and when you do max it out is speed density the only other option?
Thanks
~Tom
Old 01-09-2005, 07:25 PM
NLang's Avatar
Basically. For now anyway...
Old 01-09-2005, 10:05 PM
Another_User's Avatar
Today's interesting fact: The 2004 Hemi engines are SD.
Old 05-07-2005, 01:16 AM
LiquidFire350's Avatar
yea i know im digging up an old thread but anyways
so you guys are saying if i unplug the MAF it will go into SD, on a stock tune is that bad, better, or the same, could i run a faster time at the track with the MAF unplugged on a stock tune?
Old 05-07-2005, 07:08 AM
On a stock tune it is bad. Your car will run like crap. I don't know if it will compensate or not because it is not tuned from the factory to run in SD mode.
Old 05-07-2005, 07:59 AM
TAQuickness's Avatar
On a bone stock car, in the event the MAF were to actaully fail or gets unplugged, the PCM will compensate by falling back to the VE table and reverting to the low octane spark table, hence running like crap.
Old 05-07-2005, 10:31 AM
Oh yeah, I neglected to mention the low octane table. Because my high and low are the same, so I don't really think about it. LOL!
Old 05-07-2005, 11:15 AM
My first go at it, I forgot to copy the high to the low... crap was an understatement
Old 05-07-2005, 03:40 PM
txhorns281's Avatar
I wanna see someone who's got a sweet SD tune and their MAF calibrated well hit the dyno... I wanna see the difference b/w a descreened/ported/polished MAF vs no MAF at all. I should done this awhile back when i was on the dyno dammit... I bet the gain is quite minimal, maybe even insignificant...
With that said, SD is a great operation to get your tune inline, although I'm a proponent of going back to MAF operation once SD tuning is complete.
Old 05-07-2005, 03:58 PM
Silverhawk_02TA's Avatar
Yeah, I think the difference between the performace of a properly tuned SD vs. MAF setup (all things equal) would be negligible.
Old 05-07-2005, 04:02 PM
txhorns281's Avatar
Old 05-07-2005, 11:00 PM
Bryan Wilkinson's Avatar
I was using the MAF sensor until recently and switched to the 2 bar HP Tuners setup which is speed density, and driveability improved 100% and so did the effort requried to get it tuned right.
Old 05-08-2005, 12:36 AM
txhorns281's Avatar
With you setup, I would imagine trying to tame any airflow calculation would be difficult...
Old 05-08-2005, 02:21 AM
Robert56's Avatar
True Speed Density is Maf removed and 02's removed running in open loop mode. However, SD is also considered with 02's in closed loop mode.
Old 05-08-2005, 09:34 AM
With the setup that I have, and HP Tuners 2 Bar software and a 2 bar map, tuning with the help of some Aussie friends, it was extremely easy. Driveability is unbelievable. I cannot profess to be a qualified tuner which shows how easy HPTuners was to use.
On the Dynograph, the A/F curve and Power curves were good but not smooth when I was using the MAF. When I switched over, everything got smooth.
When I am not having to have the car go through its yearly inspection, using the stock computer I cut off the factory o2's and run in open loop mode. When I go to get inspected I cut the 02's back on.
I have the factory 02's in the front and the PLX wide bands in the rear for the gauges and tuning purposes. The car gets about 25 mpg on the hwy.
Quick Reply: Speed Density?
