MTI C1 cam guys, help?!
I have a built 5.3 motor with the C1 cam(222/222 .566/.566 112 lsa)
I am going to be tuning it with HPtuners version1.5 or 1.6. What kind of numbers timing/fuel wise should i go for and where should start out? I have used ls1edit before and i would like for this to be fairly easy for me. so, if any of you have a cam like this or similar to this, any file sharing would be very helpful. thanks
LS1TECH Sponsor
its really on a car by car basis for what fueling and timing numbers you use...on an na motor most are between 20-30 degrees of timing and as far as fueling goes again its a very broad curve...what works for one might not work for another...i would say if you dont have a wideband get it up on a dyno with a wideband and get your af strait then work on your timing.
This wideband looks pretty good if you go with the hptuners enhanced IO. https://ls1tech.com/forums/pcm-diagnostics-tuning/240435-perfect-wideband-hp-tuners.html
Wish I could help you out with the C1 tuning but I never finished my VE table since my tranny took a dump. Plus you have a 5.3 and a different MAF so it wouldn't help that much anyway.
Originally Posted by P Mack
This wideband looks pretty good if you go with the hptuners enhanced IO. https://ls1tech.com/forums/showthread.php?t=240435
