How short to go with pro 5.0
Old 01-14-2005, 12:17 PM
landonew's Avatar
Default How short to go with pro 5.0
have a pro 5.0 in my car. Isn't short enough. Was wondering what is the most i could lop off the end to make it shorter. I want a much shorter throw. I guess where the thred ends would be the determining factor, unless i could find a machine shop that would rethred it. Who has some experiance with this sort of thing. Do you just lop it off with a hack saw, or what. Dont wanna start cutting untill i am sure. Would post in manual tranny section, but there aint much traffic through there.
Old 01-14-2005, 01:39 PM
badhoopty's Avatar
i lopped mine off with a hacksaw. i cant remember how much i took off, but i made it the same length as my non-angled short stick. if you like, sometime this weekend i can measure how much threads i have left. there were enough threads left on it to where i didnt need to get it re-threaded, i also threadlocked it to try to keep everything tight.
Old 01-14-2005, 02:16 PM
777's Avatar
i'd say typically a 1/2" cut off
Old 01-14-2005, 02:20 PM
LSONE's Avatar
basically, i just measured the length of the stock threads, and cut it down untill it was the same length. basically i left this much thread left |_____|
Old 01-14-2005, 06:34 PM
ChiefBrody's Avatar
I took off an inch on mine, but I think you could go as far as an inch n a half.
Old 01-14-2005, 07:41 PM
BlueSix's Avatar
Lou's Short Stick is the way to go if you want a short throw.
Old 01-14-2005, 07:46 PM
black_ws6's Avatar
Word! $40 bucks and works perfect. I have a picture of mine here:
http://community.webshots.com/user/ws6_transam
Old 01-14-2005, 07:52 PM
z98
z98's Avatar
Cut and weld it.
Repeat as necessary.
Much better than throwing away $40.
Old 01-14-2005, 08:15 PM
landonew's Avatar
that looks real short. I take it lou is not a vendor, so i need to go and search to find one huh.
Old 01-15-2005, 12:18 AM
LSONE's Avatar
after thoughts auto sells tham, and they are a sponsor.
Old 01-15-2005, 12:25 AM
BlueSix's Avatar
Also, there is another short stick, Jarrods short stick, that is cheaper. I believe J-Rod on this board can direct you to them.
Old 01-15-2005, 11:30 AM
z98
z98's Avatar
Cut and weld it.
Old 01-16-2005, 11:32 AM
ChiefBrody's Avatar
Originally Posted by z98
Cut and weld it.
Agreed. If you have access to the tools it won't take long to make it to your liking.
Old 01-16-2005, 02:21 PM
ZR2877's Avatar
I got the angled short stick from Speed Inc for $19.99 they also have the straight short stick. I love mine and wish I did it a long time ago.
Old 01-18-2005, 07:27 PM
CamaroSS01SLP's Avatar
Werd.....love mine as well.....
Old 01-19-2005, 03:00 AM
BuBbABFP's Avatar
Do i need to have a PRO 5.0 to get the short stick, or can i just get the stick with stock shifter.. new to ls1tech hehe
Old 01-19-2005, 06:49 AM
black_ws6's Avatar
you can shorten the factory one as low as you want, but without the 5.0 you won't get the short throw to go along with the short stick.
Old 01-19-2005, 10:22 AM
That's what she said...
TheBlurLS1's Avatar
a short stick does provide a shorter throw, it would just be a shittier shifter than you already have if you do not have the factory hurst.
Old 01-19-2005, 10:46 AM
black_ws6's Avatar
The factory hurst is garbage compared to the pro 5.0 IMO.
Old 01-19-2005, 01:57 PM
z98
z98's Avatar
The hurst ******* is not any better than the factory one.
