Sponsored by: DashLynx
Factory Seats - No bolster
Old 01-15-2005, 03:01 PM
mos98c2001's Avatar
Default Factory Seats - No bolster
I have a 2001 TA and the factory seats do not seem to be functioning correctly. The power motors in the driver's seat work, but the bolster buttons on both seats do not seem to work. When I press on one of the buttons on the driver's side to adjust the bolster, i hear a click on the passenger side underneath the seat. any ideas? is there a special fuse that works just for the lumbar? hope i will not have to buy all new seats....
Old 01-15-2005, 04:26 PM
99FormulaM6's Avatar
on my old ta they didnt work either. i never decided to check on it though
Old 01-15-2005, 04:43 PM
Danny2tek's Avatar
Check the hoses underneath the seats, on my T/A they had come loose I guess it happens when the seat is moved forward and back (mine was getting cought on the tracks)
Old 01-15-2005, 05:24 PM
mos98c2001's Avatar
No, they are not stuck. there is a pump of some sorts under the passenger side. that is where the clicking is coming from. i think the pump might be bad. any ideas on how much one would cost and where to get it?
Old 01-15-2005, 09:44 PM
Danny2tek's Avatar
make sure the hoses on the pump are connected
Old 01-17-2005, 01:58 AM
Xsta Z 28's Avatar
If you hear a "click" the air pump under the pass seat must be dead . . .
Old 01-28-2005, 12:38 PM
Ozz
Ozz's Avatar
Common problem is the air hose connection under the seats come loose.
Old 01-28-2005, 12:58 PM
mc01ta's Avatar
mine came loose a month ago, found the two connectors not together, put them back and now everyhting is working great. Check under the driver seat for two connectors sitting loose
Old 01-29-2005, 10:54 PM
mos98c2001's Avatar
all the hoses are connected and still no bolster. called auto zone and they have no idea what the air pump under the seat is or will cost. any thoughts?
Old 01-30-2005, 01:00 AM
8-Pack's Avatar
I will about gaurantee it is a dealer only item, and you know what that means, it i s going to cost. Just a guess but I would say around 200 depending on location. Unless it really bugs you I would just let it go.
