Drag Wheel Weights
LS1Tech Co-Founder
I've posted the weight of Weld wheels before, but it was over a year ago. Draglites were lighter than Pro Stars, but only by a 1 lb or less than a full lb. I think that we were saying like 14 vs 15 lbs. If you call 1.800.788.weld the folks there will give you the box weight of the rims.
When I talked to Weld, the Draglights and ProStars were quoted as being the same weight. Actual weight on them might show a slight difference like PSJ said.
My XPs were close to 5 lbs heavier per rim as they are alloy and not forged aluminum.
